Detectors
Hi Guys!
I have bought a RED detector from another user.
He has forgotten login data to blitzortung, he doesn't even remember if it has ever been connected online - how to recover that?
Is that possible to add new user on that hardware?
What is worse, there is probably some error with the detector - the LCD screen is dead/dark/empty, but some diodes glow with the red light.
Someone had suggested for me to try to install new firmware for RED system.
Is that OK?
How can I download the firmware without the login/pass data??
I sincerely hope that you will spare sometime to answer the questions above
I'm looking forward to hearing from you
(2017-05-15, 19:21)adampl Wrote: Hi Guys!
Is that OK?
Check your PM for some specifics,...
basically this requires you to email Egon requesting a User ID,... you'll then be able to login and register the RED under your name. You'll then be able to access other info, including the firmware downloads from the Project Area 'compendium' tab.  If the display won't light, it's possible that it's turned off... Access the controller GUI with a computer, and look under the Settings Page for LCD settings.
@Cutty
Thank you for your reply but there is still a problem.
Device doesn't respond, LCD is dead - nothing is displayed and the LAN doesn't work - it's not even connected to network so I can't read device id.
I think I should update firmware because nothing is working for me.
How to download last firmware for RED?
(2017-05-16, 04:34)adampl Wrote: @Cutty
"I think I should update firmware because nothing is working for me."
If your unit is dead, access to firmware will do you no good....
we do not post firmware in the public forum.
I told you in the PM I sent what was required to register, and obtain firmware.
And that obviously in your case cannot be completed if the unit is dead.
An inadequate power supply also could be an issue.
You need to contact the previous owner,
or find an operator who can help you troubleshoot this system
This cannot be done in this venue.
closing this thread (moderator)
  Solar panels and detectors orion_jb2001 1 20,217 2020-08-20, 02:14
Last Post: mwaters
