No map in Firefox browser - solved in post #6
Can anyone come up with an idea as to why I am not getting the map when using http://www.lightningmaps.org/?lang=en ?
I am also missing the small map in the left margin.
I am using Firefox 54.0.1 (64 bit) in a Win 8.1 laptop.    I have the Adblocker disabled on this site.
I am not aware of any problems with any other sites.
The maps work OK in IE and Comodo Dragon (a Firefox offshoot), neither of which I use with any regularity.
I can confirm - FF 54.0 on Linux does not show the Real time map.
Errors in console:
Code:
ReferenceError: is_mobile is not defined[Zjistit více]                   index.php:1:30
TypeError: live.map_init is not a function[Zjistit více]                 www.lightningmaps.org:170:1
uncaught exception: InvalidValueError: live.map_start is not a function  (unknown)
Thank you mkyral, that suggests there may be a problem somewhere.  I am afraid that the code means nothing to me, so I cannot deduce anything from it
FF 54.0.1 (32 bit) under Windows 10 works for me
I have both maps with FF 54.0.1 (32-bit) on Linux but with warnings/errors in console.  Sound is working but performance is and always has been very sluggish. Working also on Chromium Version 59.0.3071.86 32 bit Linux.
Stations: 1527
I did some tests and it works in new profile. It also works in safe mode. So issue is probably caused by one or more add-ons. Have to find out which one.
Update: disabling of "I don't care about cookies 2.6.6" add-on helped. Map is shown now.
(2017-07-08, 05:30)mkyral Wrote: I did some tests and it works in new profile. It also works in safe mode. So issue is probably caused by one or more add-ons. Have to find out which one.
Thank you for that.  Disabling "I don't care about cookies 2.6.6" did it for me too.
For the information of other users, I just tried it using Chrome and the map was missing there. The solution was he same - disable "I don't care about cookies" (just on this site).
  Website - menus on the right side impossible to use on Firefox Zahari 2 15,783 2025-09-06, 23:20
Last Post: VA_LM_Blue
  Vector map - choosing map style Sparkee 2 21,693 2021-09-28, 09:28
Last Post: Sparkee
Exclamation Curious phenomenon on browser: https://map.blitzortung.org/ MTO-Mareuil 1 15,074 2020-12-12, 11:57
Last Post: vinesweather
Exclamation Strikes not showing after Firefox 39 update. Irish_Steve 14 104,423 2019-06-18, 10:04
