Select station
Smile
Hello, I will ask you for more experienced advice.
I installed MyBlitzortung PHP.
The program displays my map but no station selection is possible, and when I try to update it displays the following information.
2017-08-06 12:02:56 + 0ms |
2017-08-06 12:02:56 + 0ms | ***** Getting lightning data from blitzortung.org *****
2017-08-06 12:02:56 + 2ms | Information: PHP Execution timeout is 60s -> Fine Smile *** Setting MyBlitzortung timeout to: 55s
2017-08-06 12:02:56 + 3ms | Waiting 1 sec, to avoid too high load on Blitzortung servers ...
2017-08-06 12:02:56 + 1006ms |
2017-08-06 12:02:56 + 1006ms | === Strikes ===
2017-08-06 12:02:56 + 1012ms | Last strike: 2017-08-06 11:10:00 *** Loading 6 files from 2017-08-06 11:10:00 to 2017-08-06 12:00:00 *** This is update # 6
2017-08-06 12:02:56 + 12318ms | Downloading file /2017/08/06/11/10.log, last position 0 bytes: OK
2017-08-06 12:02:56 + 12318ms | Found latest strike from last import
2017-08-06 12:02:56 + 26840ms Downloading file /2017/08/06/11/20.log: OK
2017-08-06 12:02:56 + 40439ms | Downloading file /2017/08/06/11/30.log: OK
2017-08-06 12:02:56 + 54719ms | Downloading file /2017/08/06/11/40.log: OK
2017-08-06 12:02:56 + 54722ms | TIMEOUT! We will continue the next time.
2017-08-06 12:02:56 + 54722ms | Lines: 10551 *** Size: 4315kB *** New Strikes: 10550
2017-08-06 12:02:56 + 54755ms | TIMEOUT: Continue next time ...
2017-08-06 12:02:56 + 54757ms |
2017-08-06 12:02:56 + 54757ms | Import completed. Exiting ...
I do not know where there might be a mistake. This message is always displayed. The designation of my station is 1926.
Thank you for your advice.
Navoy
Stations: 1926
Have you entered your station details into the config.php file located in the base directory of your MyBlitzorgtung installation?
