High field RJ45
(2018-06-10, 18:01)gerbold Wrote:
(2017-08-25, 18:30)Banff Wrote: New sys blue kit builder here, looking for help with the 3 RJ45 connectors. Seems the front panel space for the Highfield RJ45 connector is smaller than the other RJ45 space. Just wondering if I am missing something, or if the Hf gets a different style of connector. Thanks. Jt
In case you do not have the case this plan of the back pannel may help.
Network: Ethernet cable to the network.
H-Field: RJ45 cable to the H-Field board.
Both should be shielded, for the H-Field shield is a must have.
Thank you for sending the diagram.  Egon rectified our RJ45 issue for us.  We are a "running station" now. However, as far as I can tell, we are not contributing, so I am searching for threads on the forum about how to figure out what the problems are and how to troubleshoot them.
Jt
Stations: 2206
High field RJ45 - by Banff - 2017-08-25, 18:30
RE: High field RJ45 - by N0BGS - 2017-08-25, 21:33
RE: High field RJ45 - by Norquay - 2018-06-10, 15:17
RE: High field RJ45 - by allsorts - 2017-08-25, 23:38
RE: High field RJ45 - by Norquay - 2018-06-10, 15:13
RE: High field RJ45 - by gerbold - 2018-06-10, 18:01
RE: High field RJ45 - by Norquay - 2018-06-11, 00:22
RE: High field RJ45 - by JupiterJoe - 2018-06-14, 13:07
RE: High field RJ45 - by mwaters - 2018-06-10, 18:05
RE: High field RJ45 - by gerbold - 2018-06-10, 20:14
RE: High field RJ45 - by mwaters - 2018-06-10, 21:16
RE: High field RJ45 - by kevinmcc - 2018-06-14, 03:50
