High field RJ45
(2018-06-10, 18:05)mwaters Wrote: It is no longer recommended to shield the LAN cable. But as you say, the H-field cable must be shielded.
Only post I see about this from Cutty was a suggestion for troubleshooting.
Even in that post he said he did not believe the shielded LAN cable was causing the noise.
I use as shielded LAN cable, I have no issues.
My thoughts have been to use shielded to contain the rf signal in the Ethernet cable and not radiate to the antennas.
High field RJ45 - by Banff - 2017-08-25, 18:30
RE: High field RJ45 - by N0BGS - 2017-08-25, 21:33
RE: High field RJ45 - by Norquay - 2018-06-10, 15:17
RE: High field RJ45 - by allsorts - 2017-08-25, 23:38
RE: High field RJ45 - by Norquay - 2018-06-10, 15:13
RE: High field RJ45 - by gerbold - 2018-06-10, 18:01
RE: High field RJ45 - by Norquay - 2018-06-11, 00:22
RE: High field RJ45 - by JupiterJoe - 2018-06-14, 13:07
RE: High field RJ45 - by mwaters - 2018-06-10, 18:05
RE: High field RJ45 - by gerbold - 2018-06-10, 20:14
RE: High field RJ45 - by mwaters - 2018-06-10, 21:16
RE: High field RJ45 - by kevinmcc - 2018-06-14, 03:50
