Threads: 2
Unfortunatly i completly reset the browser and stored passwords and i have forgotted the login to the web interface of the station - blue system.
I have to hardware reset the station or download again the firmware with the usb interface?
The simplies way ?
St.#1947
Threads: 63
(2017-09-03, 09:15)mirancek Wrote: Unfortunatly i completly reset the browser and stored passwords and i have forgotted the login to the web interface of the station - blue system.
The simplies way ?
St.#1947
Try this:
BOOT1: Hold this button while pressing reset: Either it enables a special debug mode (short press, then press it again) without hardware watchdog. Or you can
reset to default settings when you hold it for several seconds (until long beep).
I'm not 100% about that, but try it.... haven't had my coffee this morning...
Threads: 2
Thanks !
Solved !
I attempt with debug mode but it was unusable becouse i dont find the station on LAN. With long pressure of boot1 and so reset to default value, it works !!
So i was able to set another password.
