Signal graphs
(2017-09-17, 08:23)Alanpenwith Wrote: I have found that the system does not like google chrome - things are running better with IE and I think using manual I have got much lower noise.
Ok, I find that using the GUI when the controller is under high signal load sometimes result in a crash. Looking at the signals on lightningmaps.org, you seem to be sending hardly any signals to the servers. That might because your station is in interference mode due to excessive noise. If it is, the fault light will be on and probably lots of activity on the signal light. The UTP cable between the H-field preamp and controller MUST be shielded for starters. If you still can't get the GUI stable, disconnect the ferrite sites, the try the GUI. Set to manual, sets the gains right down low, save the config, and then reconnect the ferries. You're aiming initially for almost zero signals. Then wind up the gains slowly and see if you start you start to get signals. Then you are aiming for "just below interference level". Then you can start hunting for noise sources Smile
Stations: 1075, 1472
Signal graphs - by Alanpenwith - 2017-09-15, 17:48
RE: Signal graphs - by cutty - 2017-09-15, 18:09
RE: Signal graphs - by readbueno - 2017-09-15, 18:42
RE: Signal graphs - by Alanpenwith - 2017-09-16, 12:42
RE: Signal graphs - by readbueno - 2017-09-16, 13:33
RE: Signal graphs - by Andrew.Instone-Cowie - 2017-09-16, 20:44
RE: Signal graphs - by Alanpenwith - 2017-09-16, 13:42
RE: Signal graphs - by readbueno - 2017-09-16, 14:21
RE: Signal graphs - by pasense - 2017-09-16, 15:50
RE: Signal graphs - by Alanpenwith - 2017-09-17, 07:23
RE: Signal graphs - by Alanpenwith - 2017-09-17, 08:23
RE: Signal graphs - by Andrew.Instone-Cowie - 2017-09-17, 16:27
RE: Signal graphs - by mwaters - 2017-09-17, 18:08
RE: Signal graphs - by mwaters - 2017-09-25, 19:16
RE: Signal graphs - by readbueno - 2017-09-17, 08:29
RE: Signal graphs - by Alanpenwith - 2017-09-17, 17:38
RE: Signal graphs - by readbueno - 2017-09-17, 18:58
RE: Signal graphs - by Alanpenwith - 2017-09-21, 06:53
RE: Signal graphs - by Andrew.Instone-Cowie - 2017-09-21, 07:22
RE: Signal graphs - by allsorts - 2017-09-22, 23:23
RE: Signal graphs - by Alanpenwith - 2017-09-23, 08:10
RE: Signal graphs - by Alanpenwith - 2017-09-23, 09:06
RE: Signal graphs - by pasense - 2017-09-23, 09:29
RE: Signal graphs - by readbueno - 2017-09-23, 11:38
RE: Signal graphs - by Alanpenwith - 2017-09-23, 16:42
RE: Signal graphs - by readbueno - 2017-09-23, 17:18
