Help new system blue
#34
Assuming you have a good network patch cable that is straight-through and NOT a crossover cable, try this:
Open your router's webpage, and browsing around there you should be able to see which IP address that it has assigned to your controller. Something like http://192.168.0.1 or perhaps http://192.168.1.1 .
When you find the controller's IP, then you can view your System Blue's webpage in the same way, for example http://xxx.xxx.xxx.xxx (replacing the x's with your controller's IP that you found).
I have DHCP enabled rather than static IPs, which I think is easier.
If you don't have the manual for your router, then Google is your friend.
Help new system blue - by mikey141 - 2017-09-17, 13:37
RE: Help new system blue - by pasense - 2017-09-17, 14:04
RE: Help new system blue - by mikey141 - 2017-09-17, 14:12
RE: Help new system blue - by pasense - 2017-09-17, 14:20
RE: Help new system blue - by mwaters - 2017-09-17, 14:22
RE: Help new system blue - by mwaters - 2017-09-17, 14:33
RE: Help new system blue - by mikey141 - 2017-09-17, 14:52
RE: Help new system blue - by mwaters - 2017-09-17, 14:56
RE: Help new system blue - by mikey141 - 2017-09-17, 14:59
RE: Help new system blue - by mikey141 - 2017-09-17, 15:22
RE: Help new system blue - by pasense - 2017-09-17, 15:44
RE: Help new system blue - by mikey141 - 2017-09-17, 16:41
RE: Help new system blue - by pasense - 2017-09-17, 16:47
RE: Help new system blue - by mikey141 - 2017-09-17, 18:23
RE: Help new system blue - by pasense - 2017-09-17, 18:31
RE: Help new system blue - by mwaters - 2017-09-17, 18:31
RE: Help new system blue - by mikey141 - 2017-09-17, 18:43
RE: Help new system blue - by pasense - 2017-09-17, 19:02
RE: Help new system blue - by mikey141 - 2017-09-17, 19:08
RE: Help new system blue - by pasense - 2017-09-17, 19:10
RE: Help new system blue - by mwaters - 2017-09-17, 21:21
RE: Help new system blue - by allsorts - 2017-09-17, 19:53
RE: Help new system blue - by mikey141 - 2017-09-17, 20:00
RE: Help new system blue - by mwaters - 2017-09-17, 21:23
RE: Help new system blue - by mikey141 - 2017-09-17, 20:05
RE: Help new system blue - by readbueno - 2017-09-18, 00:18
RE: Help new system blue - by mwaters - 2017-09-18, 01:27
RE: Help new system blue - by kevinmcc - 2017-09-18, 01:27
RE: Help new system blue - by allsorts - 2017-09-22, 22:51
RE: Help new system blue - by cutty - 2017-09-18, 14:13
RE: Help new system blue - by mikey141 - 2017-09-18, 16:33
RE: Help new system blue - by mwaters - 2017-09-18, 16:39
RE: Help new system blue - by mikey141 - 2017-10-01, 17:25
RE: Help new system blue - by mwaters - 2017-10-01, 17:55
RE: Help new system blue - by readbueno - 2017-10-01, 18:29
RE: Help new system blue - by mwaters - 2017-10-01, 18:33
RE: Help new system blue - by readbueno - 2017-10-01, 18:45
RE: Help new system blue - by mikey141 - 2017-10-01, 19:06
RE: Help new system blue - by readbueno - 2017-10-01, 19:43
RE: Help new system blue - by mikey141 - 2017-10-01, 19:51
RE: Help new system blue - by readbueno - 2017-10-01, 20:13
RE: Help new system blue - by cernese - 2018-02-06, 23:24
RE: Help new system blue - by readbueno - 2018-02-07, 00:41
