Solar Powering with Power bank
Have a search through the forums, I posted a set of rough calculations based on reasonable assumptions resulting in approximate sizing of the bits required. You might be surprised, your battery is going to have to power everything, on it's own, over night. The charging system has to charge the battery for the next night *and* run the kit...
It'll be a bit tight to squeeze everything into a 5W (5 V @ 1 A) power budget. A Blue is 2 to 3W. I have a TP-Link TL-MR3020 with 4G dongle as a backup 'net connection, just powered it from the PoE switch which said it was taking 2W (4G connected, WiFi Off). Take a look at the TL-MR3020 I thnk it'll enable a Blue connected via ethernet to access the 'net via the dongle plugged into it. No power hungry WiFi...
Assuming a 1A load your battery will have to be in the order of 24 Ahr capacity. Probably more as that doesn't leave much leeway for dull days, charging and conversion effciencies etc.
Solar Powering with Power bank - by GilbertKE - 2017-11-18, 10:07
RE: Solar Powering with Power bank - by allsorts - 2017-11-19, 01:00
RE: Solar Powering with Power bank - by MrB - 2018-11-14, 15:05
  Solar panels and detectors orion_jb2001 1 7,840 2020-08-20, 02:14
Last Post: mwaters
  Powering up puzzle MonkeeRench 16 68,086 2017-06-17, 22:39
Last Post: allsorts
