Lost controller
#21
(2018-03-23, 13:28)Alanpenwith Wrote: If that is correct I should be able to find 192.168.1.235 - yes ?
Hi Alan, I hope this address is the static default address of System Blue. I could not find it in the documentation for blue but for red. Still asumig it is the same.
Let's go one step back.
The command ipconfig in the command line, which IPv4 addresses does it show for the Ethernet connection?
Once you have this IP address, get the Advanced IP Scanner and search for the entire address range of this adapter.
Let's assume Windows assigned 192.168.137.1 to your Wifi adapter, then search for 192.168.137.1-254.
Found it?
Another possibilty to find your controller has been described here: https://forum.blitzortung.org/showthread.php?tid=2112
Best regards
Klaus
Lost controller - by Alanpenwith - 2018-03-22, 16:06
RE: Lost controller - by gerbold - 2018-03-22, 17:28
RE: Lost controller - by dupreezd - 2018-03-22, 17:37
RE: Lost controller - by dupreezd - 2018-03-22, 18:37
RE: Lost controller - by Alanpenwith - 2018-03-22, 18:39
RE: Lost controller - by mwaters - 2018-03-22, 19:18
RE: Lost controller - by Alanpenwith - 2018-03-22, 20:05
RE: Lost controller - by tassyjim - 2018-03-22, 21:00
RE: Lost controller - by mwaters - 2018-03-22, 20:20
RE: Lost controller - by dupreezd - 2018-03-22, 20:27
RE: Lost controller - by Jorgeminator - 2018-03-22, 20:50
RE: Lost controller - by dupreezd - 2018-03-22, 21:13
RE: Lost controller - by mwaters - 2018-05-07, 16:10
RE: Lost controller - by mwaters - 2018-03-22, 22:49
RE: Lost controller - by tassyjim - 2018-03-22, 23:46
RE: Lost controller - by Alanpenwith - 2018-03-23, 07:52
RE: Lost controller - by gerbold - 2018-03-23, 08:35
RE: Lost controller - by Alanpenwith - 2018-03-23, 08:57
RE: Lost controller - by Alanpenwith - 2018-03-23, 09:07
RE: Lost controller - by Jorgeminator - 2018-03-23, 11:00
RE: Lost controller - by Alanpenwith - 2018-03-23, 13:28
RE: Lost controller - by gerbold - 2018-03-23, 19:48
RE: Lost controller - by mwaters - 2018-03-23, 22:19
RE: Lost controller - by Alanpenwith - 2018-03-25, 08:19
RE: Lost controller - by Alanpenwith - 2018-03-25, 10:46
RE: Lost controller - by allsorts - 2018-03-27, 10:44
RE: Lost controller - by Alanpenwith - 2018-03-28, 08:36
RE: Lost controller - by allsorts - 2018-03-30, 21:04
RE: Lost controller - by mwaters - 2018-03-30, 22:18
RE: Lost controller - by allsorts - 2018-03-31, 00:20
RE: Lost controller - by Alanpenwith - 2018-03-31, 08:50
