New station in progress
I recently took receipt of the system blue.  We hope to have it up and running before the snow flys.  I do have a question or two.  I registered for the forum.  Do I need to register anywhere else as a user once the system blue gets operational? If so, where do I do that?
Thanks in advance
L. Merry
(2018-09-17, 17:44)BerkshireCC Wrote: I recently took receipt of the system blue.  We hope to have it up and running before the snow flys.  I do have a question or two.  I registered for the forum.  Do I need to register anywhere else as a user once the system blue gets operational? If so, where do I do that?
Yes, once you have it running, you will see your User ID on the Status page. Click on that and login. Enter your User-ID (which must be kept private) and your other station info there and save it. Once the BT servers start receiving signals, you're good to go!
I think the most up-to-date documentation is on the new Wiki here. However, there is good information that you won't find there right here in the forum.
Thanks in advance
L. Merry
Hi L.
follow this description here: https://docs.lightningmaps.org/doku.php?...on:account
I hope this works. Feedback and correction is welcome.
Klaus
Stations: 2065 2729
