#41
(2019-02-19, 22:34)dupreezd Wrote:
(2019-02-19, 21:45)Blitzfeuer Wrote:
(2019-02-19, 20:48)Egon Wrote: Dear Blitzfeuer,
station 1863 is not assigned to a user!
Insert the processor ID in the "Assign a new station: (Processor-ID)" field.
Egon
Dear Egon,
Every time I have inserted such as the station number "1863" it has immediately disappeared.
Mayhaps the "Processor-ID" is not the station number at all, but rather my "User ID"?
Or mayhaps an obscure number such as that of a CPU "processor ID"?
Confused, but still trying to understand...what specifically is the mysterious "processor ID?
Blitzfeuer
Blitzfeuer, go here http://en.blitzortung.org/login.php and logon.  Then assign a new station.
Regards
Dries
Hi Dries, thanks for the graphic -- it is something I have never seen before.  Even just now I logged in again using the DE-language link you gave me, and it just shows the info I have already unsuccessfully entered, with no view corresponding to your graphic.  So a "processor ID" is really a "device ID" without the dashes.  Great, but how does one get the view you graciously presented that applies to me, User 1546, station 1863 -- simply by logging in?  Huh
Stations: 1863
Egon
Dear Egon,
Blitzfeuer
Regards
Dries
Log in to your controller (the one that you build) . Then on the Status page, about half way down, you will see the it.
Dries
Egon
Dear Egon,
Blitzfeuer
Regards
Dries
I have done it for you!
/Egon
1_i-mail.ru
2426
Europe
station not listed
Stations: 2354, 2426, 2439, 2440
http://de.blitzortung.org/station_list.p..._country=-
I can not confirm!
/Egon
user name = phobia/1883
station number = 2428
region = Australia/New South Wales
station not in station list on either site & not 'participant' on forum
We have not received any signal from the station yet. No region has been assigned yet because no position has been received yet.
/Egon
(2019-04-18, 19:52)Egon Wrote: We have not received any signal from the station yet. No region has been assigned yet because no position has been received yet.
/Egon
Yeah, I’ve not got a GPS antenna yet. Can I get participant status on the forums for some assistance with antenna designs?
AFAIK, the only way that anyone ever received participant status was after they started sending signals to the BT servers. Sorry.
A GPS antenna and an E-field probe should do that for you, provided that you have close enough strikes (the E-field probe is not sensitive enough to receive distant strikes). Otherwise, one or two 4-turn wire loops 1m in diameter should get you started as easily and inexpensively as is possible.
Station not listed
User name: Zoran.Dragic
Station number: 727
User number: 623
Europe / Croatia
Stations: 727
Hello
User Name for Forum: hazet
Station Number : 1355
Region: Europe, France
Station was listed before. Does not appear in the station list nor in the map.
Regards Hans
Mai 1st: No answer, no reaction, no explanation? Why? Is this a dead forum thread ?
Stations: 1355
My station is now listed in two countries (Asia and Oceania), and i'm not a participant on the forums. Please help.
... please try it again.
/Egon
Hi!. I'm noticed 2 different links to my station 2224
I think that something went wrong...
https://www.lightningmaps.org/blitzortun...o_sid=2224
[Image: ALsz5d.png]
https://www.lightningmaps.org/blitzortun...n_id=15061
[Image: zPqYX2.png]
Best regards, Volodymyr
Lightning Volodymyr Lightning
Station: 2224
This is really strange, unfortunately I have no idea why this is the case with this station, that can only be answered by Tobias.
/Egon
To pile on, a screenshot of another strange database query result which occurs for a couple of weeks. Hope it can help the maintainers tracing database errors.
Cheers,
afram
Stations: 1592, 2279, 2845
User Name for Forum: paul_harris77
Station Number: 2447
Region: Europe
Forum status not updated to Participant.
(2019-05-12, 05:00)lyova Wrote: Hi!. I'm noticed 2 different links to my station 2224
Hi. I found a temporary solution to this problem is removing the station from the account and re-adding station.
At the same time, the station icon on the dynamic map disappeared and does not appear for a long time(
[Image: XimEJN.jpg]
But after a while everything returned as it was in addition my station disappeared from the search by country)
Station: 2224
Your station is set to anonym, you can change it in the setting.
(2019-05-14, 17:25)Egon Wrote: Your station is set to anonym, you can change it in the setting.
Thanks Egon this is my fault(
Station: 2224
  Station List not showing any United Kingdom stations dgoadby 2 23,399 2019-04-15, 16:35
Last Post: dgoadby
  Removing Station 723 from list Ian.Cooke 5 43,122 2015-02-03, 20:39
Last Post: Toxic
