#81
(2019-06-26, 03:24)bwreed Wrote: User Name: BWREED
Station Number: 2515
Region... North America
User ID: 1939.  All station info is correct.  Anony = N.  Station does show on LightningMaps.org but not on Blitzortung.  Station details on LightningMaps does not show station as active though it is recording strikes and sending the good ones.  TIA
Brad
I can find you as a station operator on Lightninmaps, as 2526/19*39 ..but cannot find you as a station.  I also cannot receive any signals from 2515 on the Sferics.,US signals page... which means 2515 does not exist on the BLITZORTUNG station database...  examine this:
On your Blitzortung station operator's page, station setup, make sure you've entered the correct  device ID... check against your controller GUI status page:
[Image: 25151.jpg]
[Image: 25152.jpg]
IF the DEVICE IDs match,(no dashes) and"N" is entered,do nothing..this is an issue for EGON.
If it doesn't match your operator's page (no dashes)
then that's probably the reason, --The server isn't recognizing you.
(gui will show dashes ,Station Config page no dashes)
IF That's the case, you need to delete the improper station...
Scroll down a bit... check delete and save
[Image: 25153.jpg]
Then scroll back to the top, and register a new station  device, and save... you'll probably get  a new station number, also...
[Image: 25154.jpg]
The ONLY Wyoming station I can find listed is  2526, Cheyenne.
Station not on List - by dbromwich - 2019-01-23, 12:12
RE: Station not on List - by Egon - 2019-01-23, 15:20
RE: Station Isn't Recognized. Not on List. ETC - by cutty - 2019-06-26, 15:47
Not on List. ETC - by geofabryka - 2019-07-21, 06:26
  Station List not showing any United Kingdom stations dgoadby 2 23,399 2019-04-15, 16:35
Last Post: dgoadby
  Removing Station 723 from list Ian.Cooke 5 43,122 2015-02-03, 20:39
Last Post: Toxic
