Threads: 5
(2019-11-18, 21:26)Egon Wrote: The statistics on Lightningmaps.org currently only include stations that send data to Europe, Oceania or North America. I also entered Station 2588 for Oceania, but the statistics still do not seem to work. Please ask Tobias for help.
Egon
I don't know if you mean my station 2588 but I do see statistics for Oceania and think they are from my station.
Jack
Station: 2588
2019-11-21, 22:26
(This post was last modified: 2019-11-24, 02:55 by Dave:WD7K.)
user name = Dave:WD7K
station number = 2283
region = North America - Washington-state
Station was on list, data is no longer being displayed.
I believe there are two listings for station 2283.
Dave
Threads: 0
Greetings,
Can not assign new station to user database information page.
After hitting SAVE station ID disappears.
Stations: 2629
Threads: 9
your id is the long long number as shown in picture
Threads: 0
(2019-12-15, 15:15)Eric.Wouters Wrote: your id is the long long number as shown in picture
Thank you,
That solved the problem.
It should say: Device-ID not Processor-ID in the Database information entry form.
Peter
Threads: 6
Username: michidragon
Station number: 2284
Region: North America / Colorado
Issue: Second "inactive" / "no reception" station seems to be in the "Other Stations from This User" section and sits "overlaid" (and black) on top of my active station. It's ID appears to be "bo_station_id=1168" but also claims to be my live station, 2284.
Threads: 5
User Name for Forum - piepants
Station Number - 1614
Region - Oceania
Exactly the same issue as michidragon - I have a duplicate station listed on Lightningmaps.org
Correct station: https://www.lightningmaps.org/blitzortun...on_id=1672
Duplicate: https://www.lightningmaps.org/blitzortun...tion_id=95
Note that selecting "Australia / New South Wales: Newcastle" from the drop down box picks the duplicate with no signals.
Threads: 8
2020-03-31, 23:37
(This post was last modified: 2020-04-01, 10:07 by DnH2016.
Edit Reason: Problem fixed
DnH2016
1515
Oceania
Station moved to new location. Was briefly on Blitzortung in correct location. Deleted station intentionally, now cannot add it back again.
Still working on lightningmaps.org, but in wrong location.
Now fixed on Blitzortung.
On Lightningmaps.org there are two Station 1515. One is in old location Gidgegannup and this station is recording all the strokes.
The new location Baldivis does not show on the map, and shows zero strokes recorded.
Threads: 0
station not on list or map fully JERSEY CHANNEL ISLANDS UK
station 2712
ID 2087
and no 1pps gps fault
Threads: 51
(2020-05-31, 10:21)GJ7DNI Wrote: station not on list or map fully JERSEY CHANNEL ISLANDS UK
station 2712
ID 2087
Detector 2712 has not send any data up to now.
Threads: 0
my gps is i think not good for 1 pps ,i have tryed all settings all day ,will get exstetion leaad and try better sky vue ,
i think it will not send data if on gps ? with 1pps .
Threads: 0
2020-06-01, 15:48
(This post was last modified: 2020-06-01, 15:51 by Faisandi.)
hi,
i've got tow problems.
1 - can you delete my old station
- ID : 60
- region 1
2 my new station appears twice
- ID : 2293
- region 1
thanks.
Threads: 0
(2020-05-31, 19:32)Egon Wrote: (2020-05-31, 10:21)GJ7DNI Wrote: station not on list or map fully JERSEY CHANNEL ISLANDS UK
station 2712
ID 2087
/Egon i have been trying all week to sent the data that i am rx ing ??what to do next ?seems like i am just a forum user too in blue ?
Threads: 9
(2020-06-02, 13:25)GJ7DNI Wrote: (2020-05-31, 19:32)Egon Wrote: (2020-05-31, 10:21)GJ7DNI Wrote: station not on list or map fully JERSEY CHANNEL ISLANDS UK
station 2712
ID 2087
As long you don't send data, your forum status will not be upgraded. We see you have problems but solve them and the rest will follow. Think several are trying to help you.
Threads: 28
Quote:As long you don't send data, your forum status will not be upgraded. We see you have problems but solve them and the rest will follow.
I haven't been aware of this dependency. Good to know.
user name = Sputnik
user number = 2108
station number = 2722
region = Europa
Threads: 0
User name: Hogensch
Stationnumber: 125
Region: 1
station not listed
Threads: 6
User Name: lt.ning / micha.d (forum)
Station Number: 1974
Region: currently Asia, Oceania
station shown 2 times (in lightningmaps after login, in blitzortung station list/search)
Following https://www.lightningmaps.org/blitzortun...o_sid=1974 doesn't show station in the drop-down list
Supporting the first station in India 1974Stations: none In waiting list since 2017 : current rank 836
Threads: 55
(2020-07-18, 12:19)micha.d Wrote: User Name: lt.ning / micha.d (forum)
Following https://www.lightningmaps.org/blitzortun...o_sid=1974 doesn't show station in the drop-down list You are listed twice because your station is server configured to report data covering 2 regions. Lightning maps will show stations depeding on which region you've logged into on LMO. If no signals are shown in a region, depending on variousd parameters and time frames, you may not show on a specific region listing.
Threads: 0
2020-08-12, 18:03
(This post was last modified: 2020-08-12, 18:04 by Slavkowski.)
User name: slavkowski (2086)
Station: 2774
Region: Europe
1. I'm not able to assign station to user. I've been trying to assign my new station to my account since yesterday but somehow it didn't work.
2. How I Can change my status to: Participant?
