New loop antenna
I have built a loop antenna that might be a bit different. The copper tube (used to transport Freon in refrigeration systems) is a complete loop and passes through the toroid core. It seems to be working better than the home built ferite rods that I have used to this time. Also I am using channels 1B and 1C to avoid the interference I got in channel 1A. I bought the toroids many years ago so do not know the specs. There are around 50 turns of wire on secondary.
Stations: 1930
