Image with statistical information
I am currently developing a new image for the detector data with statistical informtion of the last 4 weeks. The image should help to recognized interference times and other probems.
Here is an exampl of my detector
https://map.blitzortung.org/statistic_1....omposed=10
Parameters are
station
region
minutes_composed
Greetings,
Egon
The following picture visualizes the minimum and maximum distance of the detected impact locations. The parameter specifies the station.
https://map.blitzortung.org/statistic_2....&bar_sep=4
Parameters are
station
drawing_area_height (0 - 1000, default 300)
bar_width (0 - 100, default 25)
bar_sep (0 - 100, default 4)
days (1-28)
By the way, in the first graphic I have fixed some bugs.
/Egon
Very neat and useful together with the other graph.
Thank you Egon! Bookmarked.
Really nice and usefull !
Stations: 2641 & 3138
The two scripts statistic_1.php and statistic_2.php will soon be replaced by faster versions. These are currently being tested under statistic_1b.php and statistic_2b.php. The scripts are exchanged when there is enough data available because these scripts access another data record.
/Egon
(2020-03-15, 12:53)Egon Wrote: The following picture visualizes the minimum and maximum distance of the detected impact locations. The parameter specifies the station.
Parameters are
station
days (1-28)
/Egon
Hi Egon
I'm very new and still learning. With this Min/Max graph is it possible to have it display where the strike\stroke came from? What I maen is, if it says 2556km, is it possible to display where from or at least a heading?
Many thanks
Chris
Station: 2677
The Vines Weather
Stations: 2677
(2020-02-08, 21:58)Egon Wrote: Hello,
I am currently developing a new image for the detector data with statistical informtion of the last 4 weeks. The image should help to recognized interference times and other probems. geometry dash
Parameters are
station
region
minutes_composed
Greetings,
Egon
Very nice and useful.
I notice that intermittently the data displayed on these graphs goes haywire.  At first I thought it was just my station but many others are also displaying this anomaly.  This morning around 0930 (local time, eastern Australia), 2330 UTC, I noticed that the network indicator was flashing on my receiver/controller.  Inspection of http://en.blitzortung.org/station_list.php showed it to be still online and sending data albeit way down in the list and the graphical data was exhibiting the haywire behaviour.  I presume something is going on server side but I'm curious to know whether this is part of a maintenance/upgrade process or a fault.  It's also probably not out of the question that it's a firmware bug.  I am running version 9.2 on a Blue unit V19.1.
Stations: 1527
Is it just me or it broke a few days ago? Trying to load https://map.blitzortung.org/statistic_1....2&region=1 throws a HTTP ERROR 500.
https://forum.blitzortung.org/showthread...9#pid24089
Ah, thanks. Egon's answer wasn't there when I looked at that post.
Thank you Egon for the php scripts!
  Image with statistical information Egon 43 234,456 2023-08-10, 11:37
Last Post: Danalberto231
  Information chat-bot krzysztof 2 20,691 2023-07-31, 21:46
Last Post: krzysztof
