2020-04-24, 22:28
I'm a participant (station 2441, user1905). I used to be subscribed as participant but now seem to be as a registered member. How do I change forum status to participant?
2020-04-24, 22:28
2020-04-24, 23:14
One of the admins will see this and help you. Probably Cutty will do it.
2020-04-25, 13:39
Done! Welcome aboard!
2020-05-13, 15:09
Same here! I'm a participant for station 2410, user 1887
I never had a participant status
2020-06-26, 16:19
I have station 2733 active, but nut participant status.
2020-06-30, 08:19
(This post was last modified: 2020-06-30, 08:22 by MTO-Mareuil.)
Hello !
I am a participant (station 2401 user 1880) and my profile on the forum only shows that I am registered as a member of the forum !!! how to change status? Thank you for your help. ![]()
2020-06-30, 11:46
2020-06-30, 16:36
(2020-06-30, 11:46)cutty Wrote:thank you so much !!!(2020-06-30, 08:19)MTO-Mareuil Wrote: Hello !you're updated... (no need to shout... ![]()
2020-07-20, 19:12
Dear all,
Greetings from Bulgaria. Just became a participant (thanks, Egon!). My first Station ID is 2757 and my User ID is 2114. Can you please change my status to "Participant". Thanks in advance! Kind Regards, Koleto
2020-07-21, 11:51
2020-07-21, 17:08
2020-07-29, 01:24
Hello !
I am a participant (station 2764 user 2146) and my profile on the forum only shows that I am registered, how to change status to participant. Thank you for your help.
2020-08-20, 19:05
Hi!
I have de same problem Station ID 2782 User-ID: 2155 Thanks! Mauro
2020-08-20, 19:12
(2020-08-20, 19:05)m.sedrani Wrote: Hi!there you go please do correct the settings for your station (type of antenna etc) as this will influence your signal processing.
Stations: 1476
2020-08-20, 19:23
Egon and the moderators will see it quicker if you post it there. Please read Cutty's instructions at the top first. I suggest that this thread be locked.
2020-08-20, 19:26
(2020-08-20, 19:12)Eric.Wouters Wrote:(2020-08-20, 19:05)m.sedrani Wrote: Hi!there you go
2020-08-20, 19:28
(2020-08-20, 19:23)mwaters Wrote: https://forum.blitzortung.org/showthread.php?tid=2764 ("Station Isn't Recognized. Not on List. ETC") is the correct thread for this, and the OP here should have been redirected to it. Thanks for the info. |
« Next Oldest | Next Newest »
Getting Participant status. Not sure what I'm doing wrong. | michidragon | 15 | 27,428 |
2018-10-14, 03:05 Last Post: neil9 |
Become a participant | sunwind | 4 | 10,135 |
2018-08-08, 23:21 Last Post: kevinmcc |
