HomeAssistant extension
Hello!
Any HomeAssistant users here? I've just created custom component for HomeAssistant: https://github.com/mrk-its/homeassistant-blitzortung It monitors for lightnings in given area  and provides realtime sensors with distance / azimuth / ligntning count. I try to comply with data usage rules at http://en.blitzortung.org/contact.php#contribution_7 - for example end users connect  through proxy mqtt service, so only single websocket connection to Blitzortung server is required.
Let me know what do you think about, thanks!
I've installed your HomeAssistant addon in HACS, I have no clue how to put the Blitzortung data on my map. I can usually follow an example but can't find any instructions.
