Threads: 2
We have a significant storm overhead in the Shetland islands at the moment. there are many strikes shown on the fixed size map which correlates with our local experience. However there is hardly anything showing on the dynamic size map ! I think there is a problem !
Tony Erwood
Lunna, Shetland.
08:11 GMT
Threads: 45
2020-08-21, 14:31
(This post was last modified: 2020-08-21, 15:13 by mwaters.)
(2020-08-21, 08:13)tony.erwood Wrote: We have a significant storm overhead in the Shetland islands at the moment. there are many strikes shown on the fixed size map which correlates with our local experience. However there is hardly anything showing on the dynamic size map ! I think there is a problem !
Tony Erwood
Lunna, Shetland.
08:11 GMT
Hello Tony,
Do you mean the dynamic lightningmaps.org? My guess is that you need to select
both LMO ant BTO in the drop down menu on top to the left.
Also, try the newer enhanced BTO dynamic map at
https://map.blitzortung.org/?y#3.71/57.39/0.36
Adjust the settings in the drop-down menu to suit.
Threads: 5
Hover your mouse where mine is in the snapshot, then select both.
Threads: 2
(2020-08-21, 14:31)mwaters Wrote: (2020-08-21, 08:13)tony.erwood Wrote: We have a significant storm overhead in the Shetland islands at the moment. there are many strikes shown on the fixed size map which correlates with our local experience. However there is hardly anything showing on the dynamic size map ! I think there is a problem !
Tony Erwood
Lunna, Shetland.
08:11 GMT
Hello Tony,
Do you mean the dynamic lightningmaps.org? My guess is that you need to select both LMO ant BTO in the drop down menu on top to the left.
Also, try the newer enhanced BTO dynamic map at https://map.blitzortung.org/?y#3.71/57.39/0.36
I mean
https://www.blitzortung.org/en/live_dynamic_maps3.php
I don't see any other drop down menu except the one that leads to this link.
Threads: 2
(2020-08-21, 17:14)dupreezd Wrote: Hover your mouse where mine is in the snapshot, then select both.
I don't know where you got that page from. I don't see it when viewing
www.blitzortung.org , I only see a drop down menu for "Real Time Maps" (and also "Historical Data" and "Further Info" and "Project Area").
Threads: 45
Threads: 2
(2020-08-21, 21:19)mwaters Wrote: https://www.lightningmaps.org/
Thank for that Mike, I've not seen that website before.
What is the relationship between lightningmaps.org and blitzortung.org ?
I'm reporting a problem with the blitzortung.org website that needs to be fixed.
Tony.
