Printing 3D casing for Blue-Basic
First I would like to thank the community for working on Blitzortung.
I am willing to buy a Blue-Basic board with pre-amp.
Are there any 3D casing plans to pring the enclosure ?
Kind regards,
Kellogs
I make the case for system blue. You can get a file via the link:
thingiverse dot com thing:3364124
(2025-03-19, 17:48)Kellogs Wrote: Hello,
Kind regards,
Kellogs
https://www.thingiverse.com/thing:6657494
Regards Simon
https://www.conligwx.org
Stations: 1283, 3079
I've also made a housing. Smile
Features:
- Mounting: Bottom part with screw holes or mounting adapter for easy maintenance
- Top lid holding by snappers and easily removable (screws optional)
- Show LED state on top of housing via printed optical fiber
- Holes for the additional LEDs
- Reset and action buttons (printed in place)
- Hole for DFU button
- Text and Logo in different colors
- Transparent "window": Just write station number on it or insert a piece of paper inside the housing for notes etc. (note: not really needed and weakens the lid!)
- < 80g of filament needed, small footprint
NOTE: I only have a PCB 22.0, which has a slightly different layout (LEDs, Buttons). The files here might work for PCB 22.2, but I can not guarantee!
I developed the model some months ago to learn FreeCAD. Unfortunately I was interrupted by several other things, so maybe I forgot something to mention here... So far I only printed the housing in PETG with my BambuLab X1C for my own station.
Printing notes:
- Print on textured PEI plate.
- Text must lie on bed (adjust/raise nozzle/bed temperatures if text quality is bad)
- Supports are only needed for the panels.
- Text can be colored i.e. by using the fill tool in Bambu Lab.
- The window is optional and can just be printed in the same color as the housing itself if not needed
- Optical Fiber must be printed separately with transparent material, the filling must be continuous and must not have any interruptions (see picture)!
The FreeCAD file has several parameters which can be adjusted like wall thickness, height, spacings etc. It should event be possible to adjust it to normal BLUE PCBs. Feel free to test and improve.
Have fun Lightning
Tobi
.zip   BLUE_Housing_FreeCAD.zip (Size: 2.39 MB / Downloads: 5)
.zip   MINI_Housing.3mf.zip (Size: 860.52 KB / Downloads: 4)
  System Blue Basic - Indicator Panel for Enclosure? DrFX 17 38,342 2025-09-19, 01:35
Last Post: davidmc36
  System Blue Basic availability? G3WGV 19 50,810 2025-07-04, 15:02
Last Post: carseman
  How to order system blue-basic? Kellogs 3 56,144 2025-04-20, 00:09
Last Post: DrFX
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 51,553 2025-04-19, 23:25
Last Post: DrFX
  Metal Housing for System Blue Basic DrFX 0 9,419 2025-03-08, 03:53
Last Post: DrFX
