#35
(2014-05-31, 06:37)Tobi Wrote:
(2014-05-30, 19:58)HamelGre Wrote: I tried FF (29.0.1) "New Private Window" and it landed roughly centered on the Northern tip of Denmark.
Then I tried IE (11.0.8) "In Private" and it landed centered roughly on the Poland/Belarus border.
You are right, it didn't work due to server-side caching of this page. It should work now, unless using IPv6 (supported soon).
(2014-05-30, 21:34)Cutty Wrote: Fine here with IE 10,11 and latest FF...
except... IE shows no Full Screen button , and of course won't go full screen. FF is fine, if a bit slower than IE. Cookies work as explained by Tobi on both browsers, unless I clear them.
The full screen mode is implemented as described in the documentation for each browser platform, but so far I didn't find the reason why it's not working in IE. For best speed, you should use Chrome.
Thanks, Tobi.
Greg
Stations: 706, 1682
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 3,807 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 6,135 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 7,808 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 8,791 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 4,896 2024-07-01, 07:29
Last Post: Blubbel
