(2015-05-23, 00:18)Cutty Wrote:
(2015-05-22, 23:39)Geewizard Wrote: I run station 1187.  Is it common that my station is not used for very close strikes?  I don't see my station used for strikes occurring closer than 200km when viewing http://www.lightningmaps.org/realtime? map.
that's possible.. it may be that you have too much gain, low threshold, and are sending poor data.. If your're  aiming at 'distance', the near strikes may be 'distorted'... it's also possible to go into brief interference mode with near cell activity....  Remember, this is a 'network'... no station really stands alone...
I turned down the gain and that solved the close-in detection issue.  But.....now I have to manually turn up the gain to contribute to longer-distance locations.
I do understand no station really stands alone.  Thanks.
Stations: 3173
RE: LightningMaps.org: Real-time Lightning Map - by Geewizard - 2015-05-23, 12:52
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 3,868 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 6,172 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 7,861 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 8,837 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 4,939 2024-07-01, 07:29
Last Post: Blubbel
