GPS died?
The detector suddenly reported no GPS fix yesterday. "No valid 1PPS pulse" tried to warm restart the GPS, then Cold, then rebooot the card. Nothing. And when I got home I did the same. Still no GPS fix. And when I start the card, the green light on the GPS does not blink or light or nothing. (It blinked before until it got GPS fix, now, nothing)
What could it be? Did the GPS chip die? What should I try next?
-Snicker-
Stations: 1122
Are you 100% sure it is soldered correctly - if not .... resoldering
Removing: warm throughout one side a time and gently lift few mm
Even for trained, it can be a challange to solder it correctly
Welcome to the Club Snicker. I have an old system and my gps died a few weeks ago. But on the other side, it is not really dead. The PPS keeps going, but there is no fix. I can´t imagine whats wrong.
greez
dottore
Stations: 2116
(2014-08-01, 07:28)RichoAnd Wrote: Are you 100% sure it is soldered correctly - if not .... resoldering
I can try of course, but is seems very strange. Since it suddenly happened 2 days after init. Running fine all the time. And nothing moved or touched it when it when it suddenly stopped working.
-Snicker-
Stations: 1122
Please provide a log of the GPS. How was the reception before the module has died?
Stations: 538, 672, 1534, 1555, 1696, 1712, 2034
(2014-08-01, 11:17)Tobi Wrote: Please provide a log of the GPS. How was the reception before the module has died?
I don't know where I can find any logs? The reception was excellent. I had 14 satellites in view on ext. antenna mounted on the rooftop. And very fast fix position. And no GPS errors.
Now it gives me the GPS error a minute after boot. "No valid 1PPS pulse" no matter if the ext. antenna is connected or not. No green light next to the GPS chip.
-Snicker-
Stations: 1122
Is it possible to order a new GPS module to see if that fixes it?
-Snicker-
Stations: 1122
Hello! My gps module (system blue) not view satelits with external ant. log my gps:
PMTK863,0,0,56,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,91,92,93,94,95,96,97,98,99,100,101,102,103,104,105,106,107,108,109,110,111,112,113,114
2013-01-01 00:45:14 2101 | GPS: 43752418 | GPGGA,001456.799,,,,,0,0,,,M,,M,,
2013-01-01 00:45:14 2101 | GPS: 44006738 | GPGSA,A,1,,,,,,,,,,,,,,,
2013-01-01 00:45:14 2101 | GPS: 44412104 | GPRMC,001456.799,V,,,,,0.00,0.00,060180,,,N
2013-01-01 00:45:14 2101 | GPS: ERROR, year not between 2013 and 2031 (80)
2013-01-01 00:45:14 2101 | GPS: 80-01-06 00:14:56 lat:0.000000 lon:0.000000 alt:0.0 sat:0 inview:0 fix:1 integr:N pdop:0.0 status:V
2013-01-01 00:45:14 2101 | GPS: ===========================================
2013-01-01 00:45:15 2102 | GPS: Data ERROR
2013-01-01 00:45:15 2102 | GPS: 1PPS deviation too high 4394208. Reset counter!
2013-01-01 00:45:15 2102 | GPS: 1PPS ERROR
2013-01-01 00:45:15 2102 | REMOTE-CONFIG: IP to hostname http://www.lightningmaps.org NOT found ...
2013-01-01 00:45:15 2102 | GPS: 38310840 | GPGGA,001457.799,,,,,0,0,,,M,,M,,
2013-01-01 00:45:15 2102 | GPS: 38565148 | GPGSA,A,1,,,,,,,,,,,,,,,
2013-01-01 00:45:15 2102 | GPS: 38969064 | GPRMC,001457.799,V,,,,,0.00,0.00,060180,,,N
2013-01-01 00:45:15 2102 | GPS: ERROR, year not between 2013 and 2031 (80)
2013-01-01 00:45:15 2102 | GPS: 80-01-06 00:14:57 lat:0.000000 lon:0.000000 alt:0.0 sat:0 inview:0 fix:1 integr:N pdop:0.0 status:V
2013-01-01 00:45:15 2102 | GPS: ===========================================
2013-01-01 00:45:16 2103 | GPS: Data ERROR
2013-01-01 00:45:16 2103 | GPS: 1PPS deviation too high 4523900. Reset counter!
2013-01-01 00:45:16 2103 | GPS: 1PPS ERROR
2013-01-01 00:45:16 2103 | REMOTE-CONFIG: Server switched to 0
2013-01-01 00:45:16 2103 | REMOTE-CONFIG: ERROR, NO NETWORK AVAILABLE!
2013-01-01 00:45:16 2103 | GPS: 32425800 | PMTK867,0
2013-01-01 00:45:16 2103 | GPS: 34318296 |
What i must do?
Did you solve the issue? If not, we need your station id.
