Using the amplifier only
(2014-08-06, 16:54)piotreeek Wrote: Hi,
I'm an electronic hobbyist, owning a small weather logger. I just came across the whole documentation of the project and I guess it too expensive for me to establish my own station.
However, I'd like to, at least be able to log the strikes, so I was wondering whether it is possible to use only the antenna and the amplifier and connect its outputs to my 1wire impulse meter via an analog comparator.
The main problem is - will it work without the main board?
I know that the op-amps are digitally or manually controlled through atmega8. What will happen if I don't connect the main board, just assemble the aplifier one. Will it able me to control the amplification manually?
Amplifier gain is also settable via an on board potentiometer.
Stations: 1013
Using the amplifier only - by piotreeek - 2014-08-06, 16:54
RE: Using the amplifier only - by Jonathan.Williams - 2014-08-06, 18:54
RE: Using the amplifier only - by cutty - 2014-08-07, 00:39
RE: Using the amplifier only - by piotreeek - 2014-08-07, 06:18
RE: Using the amplifier only - by RichoAnd - 2014-08-07, 07:20
RE: Using the amplifier only - by piotreeek - 2014-08-10, 10:20
RE: Using the amplifier only - by DelandeC - 2014-08-10, 11:53
RE: Using the amplifier only - by weatherc - 2014-08-10, 12:53
RE: Using the amplifier only - by cutty - 2014-08-10, 14:05
RE: Using the amplifier only - by cutty - 2014-08-10, 23:02
RE: Using the amplifier only - by piotreeek - 2014-08-11, 01:02
RE: Using the amplifier only - by cutty - 2014-08-11, 13:13
