direct connection requirement
I have my system setup in a spare room that doesnt have any direct cable internet connection, so have a WiFi device setup in station mode. This device communicates to the main Wifi router in another room, and provides a single internet cable outlet that connects direct to the System Red Controller. (This room also seems to have less EMI noise, and has better view of the GPS satellites.! )
I am using a Ubiquiti Picostation for this, see http://www.ubnt.com/airmax/picostationm/. It seems to work well and is transparent in Blitzortung setup. The main WiFi router is an Asus RT-N66, and no special settings are required. A Picostation may be a bit of an overkill for this, and you can probably find cheaper options, or rework some old router equipment to achieve the same setup (which I assume is what RichoAnd has done).
Stations: 1113
direct connection requirement - by clif9710 - 2014-08-25, 05:04
RE: direct connection requirement - by wsepe - 2014-08-25, 22:45
RE: direct connection requirement - by Michael.Sanders - 2014-08-26, 02:12
RE: direct connection requirement - by cutty - 2014-08-26, 15:14
RE: direct connection requirement - by cutty - 2014-08-26, 15:43
