Awaiting for the opportunity to order one complete set of System Blue
Moscow, Russian Federation
Keen to get a Blue for Melbourne Australia
Looking forward to getting my hands on this system. You might want to update the USB adapter information in the System Blue Assembly document to avoid confusion. The text says the plug is a USB-B, but the pictures and the part number suggest that the USB connector is actually a Mini-B.
(2016-05-12, 11:36)Jorgeminator Wrote: Looking forward to getting my hands on this system. You might want to update the USB adapter information in the System Blue Assembly document to avoid confusion. The text says the plug is a USB-B, but the pictures and the part number suggest that the USB connector is actually a Mini-B.
Good catch.. the connector is a USB Mini-B 5 pin
(2016-05-14, 12:13)Egon Wrote: Thanks for the note, I have updated the assembly instruction, further suggestions are welcome.
Not only you, the following parts are also waiting for the boards and your subsequent orders. Big Grin
Amazing! I better get that soldering iron ready.  Cool What thickness do you recommend for the solder wire?
#16
jeeeey FINALY the blue sys is out. now i need money Confused Confused
#17
Hi.
i'm interested in system blue but want a fully assemble ready to go system plug n play.
Thanks.
Stations: 970
#18
Not something very important ...
In the documentation it is spoken about "CAT" cable :
"The router is connected at the RJ45 network port with a CAT cable."
"The H-field pre-amplifier is connected with a shielded CAT cable"
"CAT" itself is not a model of cable even if everybody understand what you mean.    CAT followed by a number is a category of twisted pair cable which can be shielded or not.
UTP or FTP, CAT 5e or higher, for instance, seems more appropriate
Joël
Stations: 3207
#19
(2016-05-14, 17:09)BlackRockShooter Wrote: jeeeey FINALY the blue sys is out. now i need money  Confused  Confused
NOT YET!   Boards are in manufacturing!
(2016-05-14, 17:27)andyweather Wrote: Hi.
Thanks.
Sorry andyweather:  This system is not plug'n'play, and does not come fully assembled.
Please see the assembly instructions..
http://de.blitzortung.org/Compendium/Doc...B_20_1.pdf
#20
Thats a shame its no good to me then as i cannot solder.
Will have to stay with system red.
Stations: 970
