Threads: 8
2016-05-29, 15:42
(This post was last modified: 2016-05-29, 16:07 by psper.)
Thanks all for your answers:
As I could understand everyone think that Blitzortung is fantastic to help us take lightening pics .... but about record technic there are at least 3 different approaches.
1 - DSLR with consecutive long exposure, like we do with startrails.
2 - DSLR + some device of this kind ( http://www.radio-cb-services.com/DETECTE...LAIRS.html) that help trigger DSLR in precise moment that lightning fire.
3 - Use video and get video frames.
Pros and Cons about this 3 approaches based on your experience ?!
With Zero experience of take lightning pics, I believe that 1 and 2 output have lot more quality...even if the 3th option is 4k video.
But Option 3 (video) maybe is the easiest way to do it.
Threads: 13
I think 1 is the easiest way, you only need a DSLR and a tripod and no further device. The disadvantage is that you can do this only at night. By daylight maybe with a strong neutral-density filter.
CU Robo
Threads: 78
Great to hear that Blitzortung helps for lightning photography. Maybe we will find some solution for predicting lightning strikes, which would make things much easier for you. :-D
It would be great if you could share some of your photos here. We could also use/show them on our Facebook page.
Threads: 13
(2016-05-30, 15:25)Tobi Wrote: Maybe we will find some solution for predicting lightning strikes, which would make things much easier for you. :-D
There's some free space on the blue board. Maybe you can invent a lightning prediction unit. :-D
Threads: 8
Anybody have more info about how to detect a lightning ?
Lunarstorm777 spoke about "potential charge in the atmosphere" ...anyone have some more information ? Which type of hardware can be used to get it ?
Threads: 8
Threads: 13
(2016-05-30, 16:54)psper Wrote: Something like this ???
https://arxiv.org/ftp/physics/papers/0701/0701296.pdf
Search for portable lightning detector with the search engine of your choice.
Threads: 66
(2016-05-19, 00:00)psper Wrote: (2016-05-18, 23:38)Lunarstorm777 Wrote: Right here with you as well. Love using this app for lightning photography. Only thing that would make it better is a night-time mode for the map. What sort of things are you having trouble with?
Hi Lunarstorm777,
I never use Blitzortung before because I only discovery Blitzortung APP 3 days ago, so until now I just use 30 min delayed lightning maps and what i see and ear. I never find a good position to take photos.
Second, normaly I was lost try to find lightning or really under the strom what is very dificult to take pics. I believe that most lightning photos are a litle bit far from the lightning or under some place that we can avoid rain to make 20/30 exposures.
I use an intrevalometer to take consecutive 20/30 exposures.
Being old and worn out, I don't get much opportunity to chase lightning photograpy any more,
but..
I have an older version of
http://www.aeophoto.com/
I can tell you mine works, and you'll likely get a stroke capture if your camera is pointed toward it. You will get an exposure! Maybe not a stroke...
A camera with the fastest possible shutter lag , like a Sony A65 (approximately 50 milliseconds) for example.
Threads: 8
(2016-05-30, 20:31)Cutty Wrote: (2016-05-19, 00:00)psper Wrote: (2016-05-18, 23:38)Lunarstorm777 Wrote: Right here with you as well. Love using this app for lightning photography. Only thing that would make it better is a night-time mode for the map. What sort of things are you having trouble with?
Hi Lunarstorm777,
but..
Thanks Cutty,
Another option to consider!
Threads: 16
