Just enter the email address/country on the cover your area page.
If it is already registered you'll know your rank.
Stations: 733, 1440, 2601
(2016-08-15, 14:47)DelandeC Wrote: Just enter the email address/country on the cover your area page.
Thanks Delandec ... just discovered that !!! Waiting to be emailed...
Greetings  from Italy !
And if it is not, it will be and you'll know your rank.
Direct link to the cover your area page :
http://fr.blitzortung.org/cover_your_area.php
Be careful to put there the same email address than a previous registering.
JiPaul.
JiPaul.
Yes I understand.. But i found my rank .. thanks again !
Probably my fault, but my earlier rank was: 935
"2016-08-06, 21:52
935 out of 1151... Well, at least my forum account was activated.
Here for the long haul to put a station in Louisiana, USA (Northwest LA)"
I accidentally put in my other email today (cautery at montac dot com" and it assigned me: "1236 of 1237"
I realized my error and put in the CORRECT email, the one I used back when I originally got on the list:
NOW, the correct email "KY5G at montac dot com" shows: "1237 of 1237"
The email address I originally signed up under is KY5G at montac dot com. It is the address used on this forum account.
I would appreciate it if someone could correct this issue for me.
Don't know if I caused it, but know that I should be in line at 935 or lower if the 50 units referenced a few posts back have shipped.
As I said, I am here for the long haul. I want a unit for NW Louisiana... we don't have a single station in LA.
Stations: 1961
Sorry for the maybe stupid question.
When I signed on the list, I get an email when I reach rank 1? Or do I have regularly check the list and send an order if the first place is achieved?
And sorry for my bad english ;-)
Stations: 1597
the number of the detectors will be?
Stations: 1684, 2917
(2016-08-21, 09:20)malyan Wrote: the number of the detectors will be?
Huh  What are you asking?
(2016-08-20, 19:33)diwou Wrote: Sorry for the maybe stupid question.
You have only to wait an email from Egon. I've just received mine. It's fine :-)
and Egon put it as important so it is in red.
And don't check when you ar near the rank 1, because I think after the rank 1 you are out of the list. and if you check again you are marked as interested for an other box !... ;-)
Hello.. same things probably it is happening to me.. on Friday I was ranked at 13th, today the system says I am 1332 of 1332 ... may be I am ready to go and out the ranking ?
YES !!! Just received the email from Egon !
