Help new system blue
Sad
I took delivery of my equipment yesterday and spent all day soldering the parts to main board. I have connected up to the power supply and nothing seems to work and only led that works is power and gps. I'm really stuck now and need some help please?
I have attached a picture of what I have done and welcome your feedback please?
For some reason I can't add a picture.....
the board is 19.3c and followed the instructions on http://en.blitzortung.org/cover_your_area.php
Should be a picture now attached
Please tell us precisely what you connected. Did you connect the system to a router? Did you add a small makeshift E field antenna just to check? Or did you connect the H field ferrites?
When connecting to a router, you can check via the router which IP address the system has, make it fixed, then you can access the system interface via the browser.
Stations: 1836
(2017-09-17, 14:04)pasense Wrote: Please tell us precisely what you connected. Did you connect the system to a router? Did you add a small makeshift E field antenna just to check? Or did you connect the H field ferrites?
I just connected the system to the router using a crossover RJ45 cable and nothing else to see if the system works contently. The system wasnt looking at the router so not giving me any IP address
Do not use a crossover cable! A normal CAT5 cable is OK!!!
Stations: 1836
(2017-09-17, 13:37)mikey141 Wrote: I took delivery of my equipment yesterday and spent all day soldering the parts to main board. I have connected up to the power supply and nothing seems to work and only led that works is power and gps. I'm really stuck now and need some help please?
It looks like you have a jumper in the middle position near the USB port. When power is applied to the USB port, move the jumper from the middle to the end.
Also, the instructions are here:
https://docs.google.com/document/d/1KzPZ...1501234474
http://www.blitzortung.org/Documents/TOA...ng_RED.pdf
I've done this and nothing is working instead of the red power light and swapped over the RJ45 cable as well.
I've been using normal USB plugs that are used to charge mobile phones and do I need to looking into another power supply instead?
(2017-09-17, 14:52)mikey141 Wrote: Mike
What is your power supply?
output DC5.0V 3500MA
I've also not carried out 2.2.6 Digital filter option of the instructions and don't think that should make a difference?
I have a PCB 19.3c board and should I follow 2.3 Voltage regulator extension instructions about IC502?
