Threads: 5
Finished installing all the components onto the System Blue board..... I purchased the alum. box with my kit and when I use the on/off switch which is connected to the jumper of pin 5 and 6 I get the fault light on.....to get rid of this I push the reset button on the System Blue board and the Power and Mode lights just come on.....I can connect my gps and after just a minute the blue gps light flashes on and off continually. I then connected my network cable and the green network lite comes on steady and the lights at the network connection work as they should...green on steady and yellow flashes randomly.
I can't find the "request and account". I enter the IP address of my board in my browser, login and can see everything...Status, Settings, Tools, Signals, etc.... Under Settings/Network I find Web Interface where I checked "Need authentication:" and put the same username and password that I used to get into my IP (not sure if this is what there looking for) address and clicked on Apply...but I'm not getting an email with the information I need.....sooo I think I'm in the wrong area here...
So where is the "request and account"
Thanks for all your help...
(Manual entry by admin: Station 2334)
2382
Threads: 8
(2018-12-01, 19:27)Mike Wrote: Hello,
Hi Mike - there is no request an account link - you need to send an email to Ergon requesting it ...
Threads: 5
Do we know Ergon's email address??
Thanks,
2382
Threads: 8
(2018-12-01, 21:41)Mike Wrote: Do we know Ergon's email address??
Thanks,
He sent you the email with the offer to buy the system .... the one you responded to and gave the details of what you wanted to buy ...
Threads: 5
2018-12-01, 21:59
(This post was last modified: 2018-12-01, 22:29 by dupreezd.)
After digging I think I found it....
(Email address removed)
Thanks,
2382
Threads: 8
This is a public forum, we shouldn’t be posting his email address here which is why I didn’t
Threads: 5
2018-12-01, 23:11
(This post was last modified: 2018-12-01, 23:12 by dupreezd.)
Mike, you must log in to Blitzortung Org -
http://en.blitzortung.org/login.php
You must use the User Id and password assigned when you first registered.
Add your station there.
This is also the place to specify what antennas you have. Fill in ALL the information.
Threads: 4
[quote pid='19750' dateline='1543692474']
[/quote]
For me the request an account link only appeared on Blue's local status page, http://<local_ip_addr>/index.cgi?action=status, after I upgraded the firmware. With the shipped firmware there was no link. Check your firmware version - it should be 9.1. Hope this helps.
Threads: 5
(2018-12-01, 23:11)dupreezd Wrote: Mike, you must log in to Blitzortung Org - http://en.blitzortung.org/login.php
Thanks for your help.... but, for the life of me I don't know the login and password for the url you listed.....loginphp
My login for the forum must be different because it doesn't work either.... I did send an email to Egon asking for activation....
My unit seems to be working....good gps, good network... I can bring up
Blitzortung.org Controller and see my station...
Thanks Much
2382
Threads: 55
I already recognized the problem. The link to the login page appears when you visit the firmware start page, if the station is not assigned to a user ID. The link is at the top of the page. Unfortunately, the link is overwritten by the Javascript editing of the page, for updating some values on the page. This should be changed. You are right. It is not necessary to start the board or to reset the bord or to change the initial firmware.
Egon
