Threads: 45
By all means, upgrade! Take note of the warnings.
Threads: 45
2018-12-04, 00:10
(This post was last modified: 2018-12-04, 00:15 by mwaters.)
This is what mine looks like, FWIW.
Controller / CPU
Firmware. Rev. 9.1 BLUE / Aug 8 2018 21:10:54
Hardware Rev. 19.5 (PCB-Id 7/0)
Device-ID 1F00-0000-0000-0000-0000 [private; edited by me]
HCLK / SYSCLK / PCLKs168 / 168 / 42 / 84 MHz
CPU 57%, 33.2°C, 3.25V
Max. Memory usage. 118kB + 65kB for Signals
Signal Buffers. 34
Input Voltage 5.00V
Network
Threads: 5
Well, I've looked over the Mac and Windows firmware install and the instructions fall off of a cliff...
First one says to upgrade firmware via web interface and follow the prompts...."What Web Interface"
Second calls for a single wire debug device....???????
Third calls for flashing new firmware over the USB connector via the DfuSe .....but there's no USB connector on the Blue Board.....
Help.....
(Manual entry by admin: Station 2334)
2382
Threads: 5
(2018-12-04, 01:54)Mike Wrote: Well, I've looked over the Mac and Windows firmware install and the instructions fall off of a cliff...
Help.....
The web interface is what you see when you log on to the controller.
Tools page. Firmware.
Did you download the version 9.1?
