Live images on own websites
BO's live vector map can now be easily integrated on websites with a fixed map. The easiest way is as iframe. Here is an example.
http://map.blitzortung.org/mapexample.html
The various parameters are self-explanatory.
The following parameters with the values 0=false and 1=true are for the controls.
interactive 0/1
NavigationControl 0/1
FullScreenControl 0/1
ScaleControl 0/1
Advertisment 0/1
InfoDiv 0/1
Cookies 0/1
The settings in the menu can be controlled with the following parameters:
MapStyle 0-3
MapStyleRangeValue 0-11
Lightning Range 1-2 1-2
LightningCheckboxChecked 0/1
CourseRangeValue 0-10
CourseCheckboxChecked 0/1
CountingRangeValue 0-10
CountingCheckboxChecked 0/1
CirclesRangeValue 0-10
CirclesCheckboxChecked 0/1
SpeedRangeValue 0-10
SpeedCheckboxChecked 0/1
LinksRangeValue 0-10
LinksCheckboxChecked 0/1
Detectors Range 0-12
DetectorsCheckboxChecked 0/1
CoverageRangeValue 0-10
CoverageCheckboxChecked 0/1
DayNightRangeValue 0-10
DayNightRangeValue 0/1
AudioRangeValue 0-10
AudioCheckboxChecked 0/1
RegionRangeValue 0-9
RegionRangeValue 0/1
Have fun!
Egon
thanks for sharing the fun Egon  Lightning
Super and can you change the location there?
and zoom
(2019-12-17, 20:08)brzanek Wrote: Super and can you change the location there?
and zoom
Yes, remove interactive and NavigationControl, or set it to zero.
The initial position and zoom is set by #3/40/15 (zoom 3, latitude 40, longitude 15).
Maybe an noob question. But what do I wrong when I copy and past the code to my site https://www.onweeractueel.nl/index.html
Station: 322
Stations: 322
putting a non secure iframe in a secure page (http in https)
browsers block this now as a standard security measure.
Unless Egon install a security certificate on the map page .... not much you can do I think
(2019-12-25, 19:40)Phoenix-Blue Wrote: Maybe an noob question. But what do I wrong  when I copy and past the code to my site https://www.onweeractueel.nl/index.html
In Header, instead of
Code:
<html lang="de" style="margin: 0px; padding: 0px;"> <head> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8"> </head>
Make it
Code:
<!DOCTYPE html> <html lang="de" style="margin: 0px; padding: 0px;"> <head> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8"> <title>Phoenix Blue Page</title> </head>
It now also works via "https".
The remaining websites are still being converted.
first of all thank you very much for the possibility of the Live-Map, great thing!
While defining the URL I noticed that the parameter "RegionRangeValue" can be defined twice. - Is that correct?
Or in other words, could someone post an example for the definition of the desired region!?
Thank you very much!
Greetings
Rainer
Website: Wetter in Krentruperhagen
Stations: 271, 1811
I've a little problem.
Have anything changed for the variable "MapStyle 0-3"?
I can't see any differences between the values at the start of the request.
It comes always up with 'MapStyle=0'.
I've cleared the cache in different brouwsers everytime for the request!
I don' have any idea what's going wrong ...
Greetings
Rainer
Stations: 271, 1811
