blue ferrite / loop antenna connection?
can you tell me what is the best connection on the blue preamp between loop antenna or ferrite antenna? it has 3 inputs per antenna E1-E2-GND
Ferrite = E1-E2 and GND what is the correct connection?
Loop E1- E2 -?
Loop E1- GND -?
Loop E2- GND -?
(after soldering the bridge under the pcb)
Thank you for bringing me some details.
kind regards
Patrick Smile
 FRANCE --- RED S2401---  BLUE S2783
Stations: 2401, 2783, 3051
(2020-10-20, 08:22)MTO-Mareuil Wrote: Hi,
Loop E1- E2 -?
Loop E1- GND -?
Loop E2- GND -?
kind regards
Patrick Smile
For ferrites, three jumpers should be left open.  Those are for air core loops.
The block "GND" is for a shield ground. open otherwise.
Loop ends connect to the + and - only.  Polarity does NOT matter.
For the E pre-amp... the probe goes to the 'inboard' block, the'outer' will always be open.  There should be NO other
connections to anywhere, except the coax itself, to the E preamp.  Zero. Nil.  doing elsewise really messes up the 'mirror' capacitance of the probe, between the probe and earth. That 'capacitance' is what does the work. Don't do anything extra.
See: https://forum.blitzortung.org/showthread.php?tid=2749
