Assembled my E-field kit.
(2014-06-17, 12:50)Remy Brandt Wrote: Not gonna work here Smile We have stallions and the fence loop is more than five kilometre,drop down distance runs for miles ;D
I knew that when I got eye on this project.
Just it's more severe than I imagined from reading in.
Maybe it's because we have the M700 clock it's heavy duty stuff 10KV Jurassic park style used in wild parks and other serious animal stuff.
E antenna here is no go for at least 2000 meters Smile
I made the whole fence stuff here,there is no way to drop interference because the short burst makes the thing save.
Dropping voltage makes it harder to jump from wire thorough the fur to the animal.
If the installation here drops below 8000V we are late mowing grass.
It sounds like your fence should be generating strike counts all by itself.
Stations: 1013
It does.
I am going to test it in the back but I am still waiting for the waterproof housings I ordered.
And the distance is also to far for w-lan adding costs and more power consumption for the solar panel that is needed because there is no electricity out there.
I have two more locations... if this doesn't work I can browse another few miles for a peaceful electric blind spot Smile
I want one of those concrete windmills! Just a few KM away from here the Germans have build huge fans! The generator is about 150m high! Must be stunning reception Big Grin
Stations: 1040
If you are looking for cheap&good STP go to netwerkwinkel.com
Local shops here.. they did not knew what STP was,suckers.
Stations: 1040
Run some tests while watching football Smile It sucked,random oscillation all over the place. But we won Big Grin That's good Big Grin
Stations: 1040
(2014-06-18, 21:34)Remy Brandt Wrote: Run some tests while watching football Smile It sucked,random oscillation all over the place. But we won Big Grin That's good Big Grin
Do you go from the pre-amp (outside) with a long coax cable to the big print inside the house?
I think that I need 25 meters of coax.
Stations: 907
No problem with 25 meters of coax Wink
(2015-02-17, 11:54)DelandeC Wrote: No problem with 25 meters of coax Wink
thanks.
I Can only find a cable with 10m can I use a connector below to extend the cable?
[Image: f-connector-koppelstuk-per-stuk.jpg]
Stations: 907
Should work ok. Don't forget to weatherproof it! However Coax can be ordered in longer lengths.
Mine came from here: http://www.amazon.com/gp/product/B003FW0...UTF8&psc=1
