Data update error
i get this data error when i update. I reinstalled the script already doesnt help.
During the day, i changed psw, en then i also changed config.php with the new pasword.
the website is www.stormspotter.be/detectie
Anybody knows the problem?
2015-05-01 20:54:57 + 0ms |
2015-05-01 20:54:57 + 0ms | ***** Getting lightning data from blitzortung.org *****
2015-05-01 20:54:57 + 4ms | Information: PHP Execution timeout is 300s --> Fine Smile *** Setting MyBlitzortung timeout to: 55s
2015-05-01 20:54:57 + 8ms |
2015-05-01 20:54:57 + 8ms | === Strikes ===
2015-05-01 20:54:57 + 16ms | Last strike: 1970-01-01 00:00:01 *** Loading 13 files from 2015-05-01 18:50:00 to 2015-05-01 20:50:00 *** This is update #50
2015-05-01 20:54:57 + 1562ms | Downloading file /2015/05/01/20/50.log: Error (401 Unauthorized), 2nd try : Error (401 Unauthorized).
2015-05-01 20:54:57 + 1562ms | Lines: 0 *** Size: 0kB *** New Strikes: 0
2015-05-01 20:54:57 + 1575ms |
2015-05-01 20:54:57 + 1575ms | === Stations ===
2015-05-01 20:54:57 + 1639ms | UPDATE ERROR: [stationdata] Download of station data failed. 401 Unauthorized
2015-05-01 20:54:57 + 1640ms | ERROR: Couldn't get file for stations! Code: 401 Unauthorized
2015-05-01 20:54:57 + 1640ms | === Raw-Data ===
2015-05-01 20:54:57 + 1640ms | Not implemented!
2015-05-01 20:54:57 + 1642ms |
2015-05-01 20:54:57 + 1642ms | === Updating daily statistics (20150430) ===
2015-05-01 20:54:57 + 1644ms | Datasets: 6 Length: 183 Status: 2
2015-05-01 20:54:57 + 1646ms |
2015-05-01 20:54:57 + 1646ms | === Strike alerts ===
2015-05-01 20:54:57 + 1654ms |
2015-05-01 20:54:57 + 1654ms | Import finished. Exiting...
(2015-05-01, 20:58)WeerWest Wrote: Hello,
no 'hidden' space somewhere ?
Which version do you use?
This is a typical error in username/password
Code:
This isn't normal either.
problem solved, i had make a new psw in lightningmaps. but seems that pasword has never been changed. The old one was still active, so i used again old one.
Thx to everybody
