Controller Documentation
Hi folks
Is there somewhere a detailled manual/description available for the controller interface (Blue system)?
Examples: What is meant by Error "Overflow" Huh  or what does the parameter "HP on" flag in the amplifier section mean  Huh ?
Thanks for any clearing up hints.
Cheers Hans
Stations: 1671
Not sure about overflow, but I'm fairly certain "HP" in this case means high pass filter.
Stations: 1614
(2016-11-23, 00:24)piepants Wrote: Not sure about overflow, but I'm fairly certain "HP" in this case means high pass filter.
That's what I guessed too. However, I (and perhaps other users as well?) would be happy about documentation explaining the Blue controller interface . . . Guessing, trial and error is low efficient! Perhaps a developper may give some detailed hints?
Cheers Hans
Stations: 1671
I feel your pain.
Hours spent wandering this and http://www.wxforum.net/index.php?board=115.0
often finds contradictory information or multiple versions of the same information but slightly modified and certainly lots of people asking the same questions over and over again.
I have though received several helpful responses from these, thanks to those people.
On the web interface I found this useful, that i found by accident : https://youtu.be/Vjy7iZr-u_Y
There are also a few snippets of information that I found here : https://www.codeproject.com/articles/809...litzortung
I know this is not a commercial product and documentation takes peoples valuable time, but my time is valuable also.
I wish there was a Wiki
Stations: 1685
(2016-11-30, 23:46)nellyt Wrote: I feel your pain.
Great info and links!
I just assembled my blue unit yesterday and built the loop antenna. Now I need to figure out what all of these readings are and how the station is performing.
I'm hoping to find other users to connect with to figure all of this out. Thanks.
  computed lightning data documentation theperk 0 16,136 2024-03-25, 07:58
Last Post: theperk
