Problems displaying historical lightning data?
Hi there,
I have been having difficulty loading past lightning data on LightningMaps for at least over a month now, at the following link: https://www.lightningmaps.org/. Using this link, please try to select a day when lightning was known to occur in your area and see if anything appears (or if the correct amount of observed lightning appears like it should). At times, lightning dots would appear, but then some are noticeably missing or are only partially shown. In other cases, they would disappear randomly when zooming into the map.
In general, the dots that represent detected lightning strikes do not appear when clicking on the relevant day. I have tried different browsers and the problem persists, and I have tried on different computers. Could there be an internal problem? If so, would it be rectified soon?
Thank you, and I look forward to your response concerning this issue. Any feedback would be so greatly appreciated!
The answer is pretty simple, several servers went up in smoke with the datahouse hosting them. Read the announcement here.
It is a slow process rebuilding it.
(2021-04-16, 19:19)Eric.Wouters Wrote: The answer is pretty simple, several servers went up in smoke with the datahouse hosting them. Read the announcement here.
Ah, I see.
So, the archived data on LightningMaps.org will at least be eventually restored?
Thanks, again, for this update!
I suspect the answer is no, but are there any plans to restore the historic data?
Ah, I see.
I don't see any data before 2021-03-20, about ten days after the data loss, so I suspect anything prior is well lost.
It's unfortunate. I was looking for lightning strike data from California during August of 2020, to see the exact locations where the fires were started.
  Best way to integrate Blitzortung lightning data into a custom web application? kaileyketchum 0 407 2026-07-01, 15:25
Last Post: kaileyketchum
  What is the impact of urbanization on lightning data collection accuracy? sophia2005 4 20,960 2025-09-17, 04:51
Last Post: sophia2005
Bug Blitzortung Lightning Data does not show up in LightningMaps website ciavino.dellotto 1 20,030 2025-07-02, 06:42
Last Post: Eric.Wouters
  lightning data in a .txt or .csv (or similar) henry 3 15,724 2024-06-17, 05:38
Last Post: gerbold
  About Historical Data zumopac 1 19,194 2021-10-21, 16:54
