(2019-05-29, 07:31)djrobson Wrote:  Kupiłem jakiś czas temu zestaw bodajże "system red", używany. Nie mam kompletnie pojęcia jak to uruchomić, jak zacząć, gdzie się zalogować itp. Mam możliwość zamontowania to na dosyć wysokim obiekcie około 50m. Widzę jest kilka stacji działających obok mojej miejscowości.
Hi djrobson.
I apologize in advance I will write with the help of Google translate English)
I want to assure you that basic and the main step is that you already have a system in your hands.
And connecting it is not complicated when connecting the computer to the router)
Let me give you some installation tips.
You must have to choose the place where the main unit (PCB) is located, which requires a permanent connection to the Internet.
And where to place antennas H.Field and (E.Field system blue).
In my case this is my house's main unit located in my room antennas located on the closet away from electrical gadgets.
I want to say that the height of the antennas H.Field and E.Field is not as important as the noise from electric gadgets.
Ideally, it would be good for you to contact neighbors who have an existing station and ask for help in them.
And so write here on what step you are stuck and with God's help we will solve your problem in mounting your station.
P.S.
You can set up and run in the test mode (not permanent) even at home.
The GPS and the H.Field antenna can be placed on the window's bottom of your window.
(E.Field system blue) Antenna can not be connected at all...
System red what is yours like?
![[Image: red_1b.jpg]](http://en.blitzortung.org/Menu_Images/red_1b.jpg)
![[Image: red_2b.jpg]](http://en.blitzortung.org/Menu_Images/red_2b.jpg)
Best regards, Volodymyr
