To Tobi
Sad
Hi
Way Kant i see all mine stations User ide:148,337,614
Best regard
Lennart
Sweden
Stations: 614
Sorry, but I don't know what you mean.
Each station has a different user ID.
That's the problem Wink
(2015-05-27, 12:48)Bergkvar Wrote: Hi
Best regard
Lennart
Sweden
I know that i have 3 different stations so way Kant i Se them all
Stations: 614
I'm not sure to understand what you mean.
Where do you want to see your 3 stations ?
In your signature on this forum ?
In your own application Myblitzortung ?
In your garden ? Big Grin
Joël.
Stations: 387, 1475
Maybe he means his Signature?
Edit your signature.
http://forum.blitzortung.org/usercp.php?action=editsig
Regards Simon
https://www.conligwx.org
Stations: 1283
Exclamation
Delande is correct.... your three Green systems were registered with different user IDs
148 and 337 last sent a stroke signal yesterday, 05/28
614 hasn't sent a stroke signal since June of 2014.
As for Lightningmaps.org
...each station was created with a different User login name, and only 614 has the User Name of "Bergkvar"
the other 2 are different Logins... Only 148 has an email address registered.
You created all three stations about the same time in 2014 and haven't logged into Lightning Maps Org
since May 14 of 2014.
So, different ID numbers, and different Logins for each station.  And 614 isn't sending.  Only station
614 would show up under the User ID "Bergkvar" if all other information was correct.
I have modified your signature to reflect the other two stations...
The station status is available under the Blitzortung Participant page.
The reason is simple: Each GREEN station needs a different user id, as the authentication and identification is done via username/password.
(2015-05-28, 15:20)Tobi Wrote: The reason is simple: Each GREEN station needs a different user id, as the authentication and identification is done via username/password.
hi Tobi i have 3 different ID so that's not the problem i have check 614 and i can see it on the map but in the user list says no signals sens 2014 614 is about 26 km from mine home and i check it today and is up and running
Best regard Lennart
Stations: 148, 1598, 1601
