Last signal
Since month, on the user configuration page, there is an empty "last signal" picture, but the station works fine.
Is there a failure on transmission of my station? Dodgy
nice x-mas & HNY, Peter
Stations: 780
Hi Peter,
If you're referring to the "Blitzortung" Site, User Data page, the Signal display was 'disabled' several months ago as developers are revising server analysis.
Currently, a 'last signal' display, and FFT for your station 780 should be available at
http://www.lightningmaps.org/blitzortung...bo_sid=780
Cheers! Lightning
Stations: 689, 791, 1439
Sorry, I have eliminated the error, but you can also use the following page.
http://main.blitzortung.org/Scripts_php/...0&mode=FFT
The the new link will not work with the old green stations yet.
Egon
Stations: 2656
(2014-12-20, 07:28)Egon Wrote: Sorry, I have eliminated the error, but you can also use the following page.
Egon
Thanks for your investigation, all fine now....and happy new year, Peter
Stations: 780
