H-Field antenna for system BLUE
(2016-10-12, 13:28)DrRobin Wrote: Hi,
Sorry if this has already been answered, but my German is not up to the job.  When I first put my system blue on, I couldn't get the E field antenna to work without lots of detections/noise coming in bursts.
I then found out you need to connect the GPS antenna connector to a good earth, otherwise the E-field antenna just picks up noise.  The earth connection also improved the H-field antenna but to a smaller degree.
Robin
Hi Robin,
but where is your question or is it a recommendation? Smile   However I decided not to connect my e-field antenna since I'm living in a crowded area and there is always a lot of noise in the air.
My 2 H-field ferrit-antennas are doing a good job. Mounted them some cm above ground-level and most of the time I'm on page 2 (or 1 or 3) on the station-list. Also I'm glad to have another station 1km away from me I'm using as a reference and I'm mostly better in efficiency.
Well, in the evening hours someone in my neighbourhood turns on his TV (I think) and I receive a signal with constantly 100pulses/sec for some hours. I've covered the ferrits with aluminium-foil and grounded it but no effect.
Additionally I've grounded the housing of the controller which has contact via the GPS connector which has a little effect on the ferrit antennas results
So my recommendation is not to use the e-field antenna if you are living in an urban area.
73 de Hartmut / DK5LH
Stations: 1582
RE: H-Field antenna for system BLUE - by elythomaslumber - 2016-10-12, 14:28
  Making a copper tubing H-field antenna Geewizard 3 20,300 2025-06-02, 18:02
  Blue e-field antenna question llowrey 2 22,067 2021-07-06, 14:34
Last Post: llowrey
  My E-field antenna setup TomVal 3 27,483 2020-11-05, 15:48
  blue ferrite / loop antenna connection? MTO-Mareuil 1 19,238 2020-10-20, 11:43
  GPS antenna SYSTEM BLUE ! IK1TTD 9 75,866 2020-06-03, 12:16
Last Post: GJ7DNI
