Signal graphs
(2017-09-16, 13:42)Alanpenwith Wrote: Hi
I just have channel A set to normal B&C to don not send. Still getting the freeze when using controller (with Google Chrome).
Thanks for the input
Alan
OK Alan That is a bit Clearer.
I am going to hazard a guess and say switched mode psu. However there are two different sources of interference.
Maybe there will be someone about who is better able to help identify those.
If you have a different PSU handy, that might be the first place to start, to see if you can get a clean bare board with everything running and no interference.
As you seem to have a problem with the GPS, it may be as well to disconnect the amps for the moment and see if you can get that set up, then when that is working, proceed with the amps one at a time.
In my experience, trying to solve more than one problem at once is not normally very successful.
Brian.
Edit, You have changed something while I was typing?
Signal graphs - by Alanpenwith - 2017-09-15, 17:48
RE: Signal graphs - by cutty - 2017-09-15, 18:09
RE: Signal graphs - by readbueno - 2017-09-15, 18:42
RE: Signal graphs - by Alanpenwith - 2017-09-16, 12:42
RE: Signal graphs - by readbueno - 2017-09-16, 13:33
RE: Signal graphs - by Andrew.Instone-Cowie - 2017-09-16, 20:44
RE: Signal graphs - by Alanpenwith - 2017-09-16, 13:42
RE: Signal graphs - by readbueno - 2017-09-16, 14:21
RE: Signal graphs - by pasense - 2017-09-16, 15:50
RE: Signal graphs - by Alanpenwith - 2017-09-17, 07:23
RE: Signal graphs - by Alanpenwith - 2017-09-17, 08:23
RE: Signal graphs - by Andrew.Instone-Cowie - 2017-09-17, 16:27
RE: Signal graphs - by mwaters - 2017-09-17, 18:08
RE: Signal graphs - by mwaters - 2017-09-25, 19:16
RE: Signal graphs - by readbueno - 2017-09-17, 08:29
RE: Signal graphs - by Alanpenwith - 2017-09-17, 17:38
RE: Signal graphs - by readbueno - 2017-09-17, 18:58
RE: Signal graphs - by Alanpenwith - 2017-09-21, 06:53
RE: Signal graphs - by Andrew.Instone-Cowie - 2017-09-21, 07:22
RE: Signal graphs - by allsorts - 2017-09-22, 23:23
RE: Signal graphs - by Alanpenwith - 2017-09-23, 08:10
RE: Signal graphs - by Alanpenwith - 2017-09-23, 09:06
RE: Signal graphs - by pasense - 2017-09-23, 09:29
RE: Signal graphs - by readbueno - 2017-09-23, 11:38
RE: Signal graphs - by Alanpenwith - 2017-09-23, 16:42
RE: Signal graphs - by readbueno - 2017-09-23, 17:18
