2018-03-22, 23:46
(2018-03-22, 22:49)mwaters Wrote: What is the source of the wired network? Your ISP? If so, where is the router/firewall? The latter is where it is customary to configureĀ the IPs and NAT.His original Internet was through a satellite connection. They are typically slow and suffer from very high latency. Been there - done that.
For the satellite connection he would have used a standard router connected to the satellite 'modem'.
He has changed to a 'mobile' Internet which is much faster and better all round if you have good mobile reception. The new internet uses a WiFi only modem/router hence the need to change.
He is having difficulties using the Windows network bridge which should allow a device connect to the Ethernet on the PC to use the PC's WiFi for Internet access.
Jim
Stations: 2048
