2022-11-07, 23:23
(2022-11-07, 21:59)cernese Wrote: I've been running a "blue" system since the fall of 2017!Hi Dan... have you seen this thread???
At the end of last month, near end-October-2022, I get a startup sequence where the GPS unit responds and then dies.
First 1 satellite and a few seconds later, a 2nd satellite, and then it stops responding completely.
It was an inexpensive "active antenna 28dB Gain, 3-5VDC, SMA connector" widget and I'm going to order a replacement unit, any suggestions or should I just pick what I find in amazon.com ?
Thanks,
Dan
