Ferrite Rod Antenna Shielding
(2014-08-18, 08:43)Eric.Wouters Wrote: But don't forget to let a little line parallel to the antenna unshielded or you end with no signal at all Wink (good way to test external interference)
Ok, so I need a space in the shielding running the length of the ferrite rod enclosure?
Does the size of this gap matter? e.g. 1mm 2mm etc.
Does the orientation of the gap matter? e.g. If I'm looking down through the conduit and they are in the horizontal plane, does it need to be at 12, 3, 6, 9 o'clock position, as I am putting these up on my roof, I'm guessing somewhere between 9 through 12 to 3 (i.e. top half) would improve shielding from anything in the house.
Stations: 1147, 1365
Ferrite Rod Antenna Shielding - by Dave.Auld - 2014-08-18, 08:20
RE: Ferrite Rod Antenna Shielding - by Dave.Auld - 2014-08-18, 08:53
  blue ferrite / loop antenna connection? MTO-Mareuil 1 19,459 2020-10-20, 11:43
  Shielding Alanpenwith 1 22,795 2017-10-22, 10:36
Last Post: readbueno
  Blue H field Ferrite antenna in L or Delta shape? nellyt 8 76,116 2017-03-30, 03:06
Last Post: Mike6158
  H-Field Ferrite Rod Antena Parameters dieron 2 28,353 2017-02-28, 19:10
Last Post: RichoAnd
Photo H field ferrite shielding orion_jb2001 5 52,500 2015-01-30, 03:58
Last Post: orion_jb2001
