column header
(2015-06-19, 20:01)hazet Wrote: Hi Gerhard
Thanks for your reply! It's what I guessed but was not sure about . . .
However, how to improve signal quality with an e-Field amplifyer as this one adjusts automatically? Can it be achieved only by displacement of the ferrit rod antennas or is there any other way to lower interference / improve signal quality? Any hints?
Hans
Hi Hans,
You are using the H-field amp. The first thing i did was test out different locations for the ferrites. Then i made a good, clean ground, by hammering a 2m long copper pipe in the ground. We have easy soil for that here;-) no rocks! do not use the ground from the electrical system in your house, and only ground the controller, not the amp! After that i did a lot of testing and trying different gain and threshols settings, till i got it right (I hope...)
have fun
Gerhard
Stations: 711, 1351
column header - by hazet - 2015-06-19, 14:17
RE: column header - by Gerhard.Wittevee - 2015-06-19, 17:12
RE: column header - by hazet - 2015-06-19, 20:01
RE: column header - by Gerhard.Wittevee - 2015-06-20, 15:39
RE: column header - by hazet - 2015-06-21, 05:51
RE: column header - by cutty - 2015-06-21, 10:49
RE: column header - by hazet - 2015-06-21, 15:19
RE: column header - by cutty - 2015-06-21, 15:49
