Low Pass Filter problems
Thanks Andrew,
I have found the schematics.  It looks like a problem with one of the multiplexers or signal lines when the filter is selected on the E channel.  I will have to trace through with a scope probe.
Hartmut
This morning I made a note of the gain settings whilst running under 'automatic' and then adjusted the gains using manual mode on the channels I have LP filters fitted.  I am now running much higher gain on the two channels with LP filters, the noise has come back up a bit, but signal to noise has gone up a lot.
There is quite a lot of activity around North Africa and southern Greece just now and my two H-field antennas with LP filters are much more sensitive and picking up these strokes much better since making the change.
I am going to see how well it runs today and then look at thresholds.  After which I will document my findings.
Robin
  Vin too low mt007 3 26,870 2016-12-04, 12:40
Last Post: allsorts
  Low gain on this system (Waregem) Noodweer Benelux 9 59,296 2015-07-18, 03:09
Last Post: JamesPatterson
  New station, very low stroke number Gianfran 2 22,828 2014-12-27, 09:47
  Low effectivity Snicker 13 87,584 2014-07-30, 21:24
Last Post: W3DRM
