Fault mode after big electrostatic discharges.
Dears,
My station stopped receiving discharges. It is "Station 2927, BLUE, FW 9.4, PCB 19.5/H1/E1"
'Fault' LED is continuously on, I believe because of 'Fault' mode.. because of overload/interference?
Everything began on a day, when there were big electrostatic discharges in air.
Radar's antennas collected static, and presumably, burnt something on PCB.
Radar was connected to Internet via unmanaged switch over ethernet cable, which has been burnt that night - had to be replaced.
Static was so powerful, that I heard 'clicks' in the middle of the night from another room. I walked into the room where radar was located and saw sparks near antenna connector. I had to use insulated pliers to unscrew F-connector.
Good news: built-in GPS module works, network adapter works.
With disconnected antennas, from debug log:
---snip---
2024-01-30 16:27:26  488.1 | AUTO 1/2: [TOO MUCH NOISE] noise=8 thr_old=1 thr_new=11
2024-01-30 16:27:26  488.1 | AUTO 1/1: [ADJUST GAIN] noise=6 factor=10.62 thr_old=8 factor_real=0.00 gain_new=-1
2024-01-30 16:27:26  488.1 | AUTO 1/2: [ADJUST GAIN] noise=8 factor=7.73 thr_old=11 factor_real=0.00 gain_new=-1
2024-01-30 16:27:27  489.1 | AUTO 1/1: [TOO MUCH NOISE] noise=7 thr_old=1 thr_new=10
2024-01-30 16:27:27  489.1 | AUTO 1/2: [TOO MUCH NOISE] noise=8 thr_old=1 thr_new=11
2024-01-30 16:27:28  490.1 | AUTO 1/1: [TOO MUCH NOISE] noise=7 thr_old=1 thr_new=10
2024-01-30 16:27:28  490.1 | AUTO 1/2: [TOO MUCH NOISE] noise=9 thr_old=1 thr_new=12
2024-01-30 16:27:29  491.1 | AUTO 1/1: [TOO MUCH NOISE] noise=7 thr_old=1 thr_new=10
2024-01-30 16:27:29  491.1 | AUTO 1/2: [TOO MUCH NOISE] noise=8 thr_old=1 thr_new=11
2024-01-30 16:27:30  492.1 | AUTO 1/1: [TOO MUCH NOISE] noise=7 thr_old=1 thr_new=10
2024-01-30 16:27:30  492.1 | AUTO 1/2: [TOO MUCH NOISE] noise=8 thr_old=1 thr_new=11
2024-01-30 16:27:31  493.0 | AUTO 1/1: [TOO MUCH NOISE] noise=7 thr_old=1 thr_new=10
2024-01-30 16:27:31  493.0 | AUTO 1/2: [TOO MUCH NOISE] noise=8 thr_old=1 thr_new=11
2024-01-30 16:27:32  494.0 | AUTO 1/1: [TOO MUCH NOISE] noise=7 thr_old=1 thr_new=10
2024-01-30 16:27:32  494.0 | AUTO 1/2: [TOO MUCH NOISE] noise=8 thr_old=1 thr_new=11
---snip---
I did open receiver and visually inspected with a loupe, there is no visible damage.
I belive, that static damaged something, but my knowledge is limited to design/construction.
Anybody has similar issues?
Where to troubleshoot?
Any help is appreciated.
BR /Anton
It looks like you are in Auto mode and going into interference mode. On the Settings tab under Remote Control, set you controller to Manual. Then under Amp 1 set all channels  to 10*10 and a threshold of 100mV and see what it looks like then.
Also disconnect the H amplifier to isolate noise coming from there. You might have noise/interference  from another damaged device or power supply.
Components such as resistors, capacitors, or even integrated circuits can be completely burned out by the large discharge currents that pass through them. Run 3
  fault led at first boot uvash 3 13,508 2021-11-18, 10:37
Last Post: aloha20
  How to get alerts of fault or missing GPS jchonig 2 9,575 2020-12-30, 18:23
  Fault LED indicates fault j82 10 61,642 2016-09-20, 08:40
Last Post: Tobi
