Threads: 3
Hi all,
I have just setup my new station #3242 and are having trouble linking my account to the forum.
Would I be able to get some help to link the accounts so that I can access the participant section of the forum.
Thanks in advance
Jamie
Threads: 64
upgraded your profile
Noted your 3242 is only reporting to European regions, and is currently 'idle'... as soon as you get it online for 24 hrs, if it DOESN'T start reporting to 'Oceania', you might email Egon, and 'nudge' him that your station is in Oceania, Australia, and could he please check region assignment(s). (This happens because the firmware, and initial ops check is done in Germany)...
Welcome Aboard!
Threads: 3
(2026-01-13, 04:19)cutty Wrote: upgraded your profile
Welcome Aboard!
Thanks Cutty,
I have had the system powered up for about an hour now so will see if it changes to the correct region.
Lots of reading and learning to be done now to make sure I am able to contribute to this great network.
Threads: 64
(2026-01-13, 04:23)jamieh Wrote: (2026-01-13, 04:19)cutty Wrote: upgraded your profile
Welcome Aboard!
Thanks Cutty,
Threads: 3
(2026-03-19, 14:35)cutty Wrote: (2026-01-13, 04:23)jamieh Wrote: (2026-01-13, 04:19)cutty Wrote: upgraded your profile
Welcome Aboard!
Thanks Cutty,
I ended up messaging Egon and he fixed up the database issue to get my station to report to the correct regions.
It has been running great and I am pretty happy with how it is performing.
Threads: 6
Hi Jamie, I just had a quick look at your weather site. You might want to change your stated latitude from North to South :-)
Threads: 3
(2026-03-20, 06:39)nerd65 Wrote: Hi Jamie, I just had a quick look at your weather site. You might want to change your stated latitude from North to South :-)
Thanks and good pick up.
Latitude updated now.
