"Symmetrical noise" on H-field
(2016-06-13, 22:00)Jorgeminator Wrote: What causes this kind of noise? I'm seeing it frequently on my station and other stations as well.
[Image: Gt5zYp6.png]
What you see isn't 'noise'... Your station signal data is compression encoded, and what you see is the result at the server. If I understand correctly, those areas indicate the part of that specific channel signal that wasn't sent. because it was noisy, or otherwise not used, or necessary. You see a server 'artifact' that restores the 'timing' between the used portions.  Saves bandwidth among other things. Whether it's visible or not is controlled by the server operation...
RE: "Symmetrical noise" on H-field - by cutty - 2016-06-13, 22:43
